Open Source Mali GPUs Android Gralloc Module
Android Gralloc Module Source Code For Mali-200/300/400/450, Mali-T6xx/T7xx/T860/T880, and Mali-Gxx based GPUs. Linux/Android Gralloc Module Under Apache License.
This is an Android Gralloc module which allocates memory from the ION memory manager. Android’s composition engine uses the Gralloc module to allocate and manage memory which is suitable for 2D and 3D graphics usage. The Mali GPU driver stack can use ION memory directly, resulting in zero-copy operations when compositing.
This component is not a complete driver stack. To build a functional OpenGL ES or Vulkan driver, you need access to the full source code of the Mali GPU Device Development Kit (DDK), which is provided under the standard Arm commercial licence to all Mali GPU customers. For a complete integration of the Mali GPU DDK with the Android environment refer to the Integration Guide supplied with the Mali GPU DDK.
The open-source code that is provided on this page is designed to run with a version-compatible release of the Mali GPU DDK. By releasing this software under the Apache licence, we hope to make it easier to include Mali GPU drivers in any Android platform.
Features
The Android Gralloc module:
  • Implements Android interfaces for managing allocations and CPU mapping of graphic buffers.
  • Provides an interface for access to allocated ION memory through a shared file descriptor. This enables memory to be shared across different applications, drivers, and hardware components to facilitate zero-copy operations.
Mali Valhall GPUs
Download Android Gralloc Source code for Mali Valhall GPUs:
VX504X08X-SW-99005-r21p0-01rel0.tar Android Gralloc Module r21p0-01rel0 (Valhall). Released on 4th November 2019. 610 KB
VX504X08X-SW-99005-r20p0-01rel0.tar Android Gralloc Module r20p0-01rel0 (Valhall). Released on 21st August 2019. 510 KB
VX504X08X-SW-99005-r19p0-01rel0.tar Android Gralloc Module r19p0-01rel0 (Valhall). Released on 26th June 2019. 500 KB
Mali Bifrost GPUs and Valhall GPUs
Download Android Gralloc Module Source Code for Mali Bifrost GPUs and Valhall GPUs:
VX504X08X-SW-99005-r25p0-01eac0.tar Android Gralloc Module r25p0-01eac0 (Valhall). Released on 16th June 2020. 560 KB
BX304L01B-SW-99005-r25p0-01eac0.tar Android Gralloc Module r25p0-01eac0. Released on 16th June 2020. 560 KB
VX504X08X-SW-99005-r24p0-01rel0.tar Android Gralloc Module r24p0-01rel0 (Valhall). Released on 14th April 2020. 540 KB
BX304L01B-SW-99005-r24p0-01rel0.tar Android Gralloc Module r24p0-01rel0. Released on 14th April 2020. 540 KB
VX504X08X-SW-99005-r23p0-01rel0.tar Android Gralloc Module r23p0-01rel0 (Valhall). Released on 13th February 2020. 590 KB
BX304L01B-SW-99005-r23p0-01rel0.tar Android Gralloc Module r23p0-01rel0. Released on 13th February 2020. 590 KB
VX504X08X-SW-99005-r22p0-01rel0.tar Android Gralloc Module r22p0-01rel0 (Valhall). Released on 17th January 2020. 610 KB
BX304L01B-SW-99005-r22p0-01rel0.tar Android Gralloc Module r22p0-01rel0. Released on 17th January 2020. 610 KB
BX304L01B-SW-99005-r21p0-01rel0.tar Android Gralloc Module r21p0-01rel0. Released on 4th November 2019. 610 KB
BX304L01B-SW-99005-r20p0-01rel0.tar Android Gralloc Module r20p0-01rel0. Released on 21st August 2019. 510 KB
BX304L01B-SW-99005-r19p0-01rel0.tar Android Gralloc Module r19p0-01rel0. Released on 26th June 2019. 500 KB
BX304L01B-SW-99005-r18p0-01rel0.tar Android Gralloc Module r18p0-01rel0. Released on 3rd May 2019. 490 KB
BX304L01B-SW-99005-r17p0-01rel0.tgz Android Gralloc Module r17p0-01rel0. Released on 5th March 2019. 66 KB
BX304L01B-SW-99005-r16p0-01rel0.tgz Android Gralloc Module r16p0-01rel0. Released on 6th December 2018. 65 KB
BX304L01B-SW-99005-r15p0-01rel0.tgz Android Gralloc Module r15p0-01rel0. Released on 27th September 2018. 47 KB
BX304L01B-SW-99005-r14p0-01rel0.tgz Android Gralloc Module r14p0-01rel0. Released on 31st July 2018. 45 KB
BX304L01B-SW-99005-r13p0-01rel0.tgz Android Gralloc Module r13p0-01rel0. Released on 8th June 2018. 44 KB
BX304L01B-SW-99005-r12p0-01rel0.tgz Android Gralloc Module r12p0-01rel0. Released on 26th April 2018. 44 KB
BX304L01B-SW-99005-r11p0-01rel0.tgz Android Gralloc Module r11p0-01rel0. Released on 9th March 2018. 44 KB
BX304L01B-SW-99005-r10p0-01rel0.tgz Android Gralloc Module r10p0-01rel0. Released on 23rd January 2018. 41 KB
BX304L01B-SW-99005-r9p0-01rel0.tgz Android Gralloc Module r9p0-01rel0 (Released on 09 Nov 2017) 41 KB
BX304L01B-SW-99005-r8p0-01rel0.tgz Android Gralloc Module r8p0-01rel0 (Released on 20 Sep 2017) 41 KB
BX304L01B-SW-99005-r7p0-01rel0.tgz Android Gralloc Module r7p0-01rel0 (Released on 10 Jul 2017) 39 KB
BX304L01B-SW-99005-r6p0-01rel0.tgz Android Gralloc Module r6p0-01rel0 (Released on 15th May 2017) 42 KB
BX304L01B-SW-99005-r5p0-01rel0.tgz Android Gralloc Module r5p0-01rel0 (Released on 24 Mar 2017) 37 KB
BX304L01B-SW-99005-r4p0-01rel0.tgz Android Gralloc Module r4p0-01rel0 (Released on 20 Jan 2017) 29 KB
BX304L01B-SW-99005-r3p0-00rel0.tgz Android Gralloc Module r3p0-00rel0 (Released on 22 Nov 2016) 30 KB
BX304L01B-SW-99005-r2p0-03rel0.tgz Android Gralloc Module r2p0-03rel0 (Released on 7 Oct 2016) 30 KB
BX304L01B-SW-99005-r1p0-01rel0.tgz Android Gralloc Module r1p0-01rel0 (Released on 1 Aug 2016) 39 KB
BX304L01B-SW-99005-r0p0-06rel0.tgz Android Gralloc Module r0p0-06rel0 (Released on 1 June 2016) 37 KB
Mali Midgard GPUs
Download Android Gralloc Module Source Code for Mali Midgard GPUs:
TX041-SW-99005-r29p0-01rel0.tar Android Gralloc Module r29p0-01rel0. Released on 5th December 2019. 610 KB
TX041-SW-99005-r28p0-01rel0.tgz Android Gralloc Module r28p0-01rel0. Released on 6th December 2018. 65 KB
TX041-SW-99005-r27p0-01rel0.tgz Android Gralloc Module r27p0-01rel0. Released on 27th September 2018. 47 KB
TX041-SW-99005-r26p0-01rel0.tgz Android Gralloc Module r26p0-01rel0. Released on 31st July 2018. 45 KB
TX041-SW-99005-r25p0-01rel0.tgz Android Gralloc Module r25p0-01rel0. Released on 8th June 2018. 44 KB
TX041-SW-99005-r24p0-01rel0.tgz Android Gralloc Module r24p0-01rel0. Released on 26th April 2018. 44 KB
TX041-SW-99005-r23p0-01rel0.tgz Android Gralloc Module r23p0-01rel0. Released on 9th March 2018. 44 KB
TX041-SW-99005-r22p0-01rel0.tgz Android Gralloc Module r22p0-01rel0. Released on 23rd January 2018. 41 KB
TX041-SW-99005-r21p0-01rel0.tgz Android Gralloc Module r21p0-01rel0 (Released on 09 Nov 2017) 41 KB
TX041-SW-99005-r20p0-01rel0.tgz Android Gralloc Module r20p0-01rel0 (Released on 20 Sep 2017) 41 KB
TX041-SW-99005-r19p0-01rel0.tgz Android Gralloc Module r19p0-01rel0 (Released on 10 Jul 2017) 39 KB
TX041-SW-99005-r18p0-01rel0.tgz Android Gralloc Module r18p0-01rel0 (Released on 15 May 2017) 42 KB
TX041-SW-99005-r17p0-01rel0.tgz Android Gralloc Module r17p0-01rel0 (Released on 24 Mar 2017) 37 KB
TX041-SW-99005-r16p0-00rel0.tgz Android Gralloc Module r16p0-00rel0 (Released on 20 Jan 2017) 29 KB
TX041-SW-99005-r15p0-00rel0.tgz Android Gralloc Module r15p0-00rel0 (Released on 22 Nov 2017) 30 KB
TX041-SW-99005-r14p0-01rel0.tgz Android Gralloc Module r14p0-01rel0 (Released on 7 October 2016) 30 KB
TX041-SW-99005-r13p0-00rel0.tgz Android Gralloc Module r13p0-00rel0 (Released on 27 July 2016) 39 KB
TX041-SW-99005-r12p1-05rel0.tgz Android Gralloc Module r12p1-05rel0 (Released on 29 Sept 2016) 37 KB
TX041-SW-99005-r12p0-04rel0.tgz Android Gralloc Module r12p0-04rel0 (Released on 1 June 2016) 37 KB
TX041-SW-99005-r11p0-00rel0.tgz Android Gralloc Module r11p0-00rel0 (Released on 4 March 2016) 36 KB
TX041-SW-99005-r10p0-00rel0.tgz Android Gralloc Module r10p0-00rel0 (Released on 8 February 2016) 35 KB
TX041-SW-99005-r9p0-05rel0.tgz Android Gralloc Module r9p0-05rel0 (Released on 16 December 2015) 34 KB
TX041-SW-99005-r8p0-02rel0.tgz Android Gralloc Module r8p0-02rel0 (Released on 4 November 2015) 34 KB
TX041-SW-99005-r7p0-02rel0.tgz Android Gralloc Module r7p0-02rel0 (Released on 21 August 2015) 34 KB
TX041-SW-99005-r6p0-02rel0.tgz Android Gralloc Module r6p0-02rel0 (Released on 22 June 2015) 32 KB
TX041-SW-99005-r5p1-00rel1.tgz Android Gralloc Module r5p1-00rel1 (Released on 26 February 2015) 21 KB
TX041-SW-99005-r5p1-00rel0.tgz Android Gralloc Module r5p1-00rel0 (Released on 17 February 2015) 21 KB
TX041-SW-99005-r5p0-06rel0.tgz Android Gralloc Module r5p0-06rel0 (Released on 15 December 2014) 21 KB
TX041-SW-99005-r4p1-00rel0.tgz Android Gralloc Module r4p1-00rel0 (Released on 7 July 2014) 14 KB
TX041-SW-99005-r4p0-02rel0.tgz Android Gralloc Module r4p0-02rel0 (Released on 4 April 2014) 14 KB
Mali Utgard GPUs
Download Android Gralloc Module Source Code for Mali Utgard GPUs:
DX910-SW-99005-r10p0-00rel0.tgz Android Gralloc Module r10p0-00rel0 (Released on 26th September 2019) 15 KB
DX910-SW-99005-r9p0-01rel0.tgz Android Gralloc Module r9p0-01rel0 (Released on 17th September 2018) 15 KB
DX910-SW-99005-r8p1-00rel0.tgz Android Gralloc Module r8p1-00rel0 (Released on 11th January 2018) 15 KB
DX910-SW-99005-r8p0-01rel0.tgz Android Gralloc Module r8p0-01rel0 (Released on 15 Sep 2017) 14 KB
DX910-SW-99005-r7p0-00rel1.tgz Android Gralloc Module r7p0-01rel1 (Released on 20 Jan 2017) 12 KB
DX910-SW-99005-r7p0-00rel0.tgz Android Gralloc Module r7p0-00rel0 (Released on 13 September 2016) 12 KB
DX910-SW-99005-r6p2-01rel0.tgz Android Gralloc Module r6p2-01rel0 (Released on 14 July 2016) 12 KB
DX910-SW-99005-r6p1-01rel0.tgz Android Gralloc Module r6p1-01rel0 (Released on 2 March 2016) 12 KB
DX910-SW-99005-r6p0-01rel0.tgz Android Gralloc Module r6p0-01rel0 (Released on 10 November 2015) 12 KB
DX910-SW-99005-r6p0-01rel1.tgz Android Gralloc Module r6p0-01rel1 (Released on 13 January 2015) 12 KB
DX910-SW-99005-r5p2-00rel0.tgz Android Gralloc Module r5p2-00rel0 (Released on 19 May 2015) 12 KB
DX910-SW-99005-r5p1-01rel0.tgz Android Gralloc Module r5p1-01rel0 (Released on 17 March 2015) 12 KB
DX910-SW-99005-r5p0-01rel0.tgz Android Gralloc Module r5p0-01rel0 (Released on 11 November 2014) 12 KB
DX910-SW-99005-r4p1-01rel0.tgz Android Gralloc Module r4p1-01rel0 (Released on 07 July 2014) 12 KB
DX910-SW-99005-r4p0-00rel1.tgz Android Gralloc Module r4p0-00rel1 (Released on 06 May 2014) 12 KB
