System Memory Management Units
The Arm System Memory Management Units
The System Memory Management Unit family
White paper: Enterprise Virtualization with Arm CoreLink SMMU and Arm CoreLink GIC
Download
Highlights
CoreLink MMU-600AE features
  • Meets automotive safety requirements for building high-performance ASIL B to ASIL D systems.
  • Software compatible with MMU-600 with Arm v8.2 compliant RAS reporting interface.
  • Efficient functional logic duplication, ECC and address protection for SRAM.
  • AMBA extensions for interface protection.
  • Fault management unit to simplify error reporting, testing and integration.
Download TRM
CoreLink MMU-600 features
  • Enhances CoreLink MMU-500 feature set by incorporating SMMUv3.1 specification to support Armv8.2 CPUs.
  • Expands the number of contexts supported to millions.
  • Implements AMBA-DTI to interface TBU and TCU to improve scalability.
  • Multi-level TLB and Walk Cache improves system address translation hit rates.
  • Improved write buffer depth and parallel translations.
Diagram on enterprise for CCN502 to 512.
CoreLink MMU-500 Features
  • Builds on top of MMU-400 features by implementing SMMUv2 architecture adding support for Armv8 CPUs.
  • Supports Stage 1, Stage 2, and Stage1 followed by Stage 2 address translation for up to 128 active device contexts.
  • Implements a distributed Translation Buffer Unit (TBU) micro-architecture with direct point-to-point connections between each TBU and the centralized Translation Control Unit (TCU) for Page Table Walks (PTWs).
  • Supports up to 128 entries per TLB which is further backed by TCU cache up to 2K entries.
CoreLink MMU-401 Features
  • Supports SMMUv1 architecture for Armv7 CPUs and Arm v8 for 64KB page sizes.
  • Performs stage2 translation only for hypervisor support.
  • Implements a single TBU micro-architecture with connection to a single TCU for page table walks.
MMU-500 Block Diagram
CoreLink MMU-500 Characteristics
The CoreLink MMU-500 supports the translation formats of Armv7 and Armv8 architectures and performs Stage 1, Stage 2, or Stage 1 followed by Stage 2 translations for all page sizes except 16KB page granule for Armv8. The MMU-500 is implemented as a distributed design with one or more TBUs communicating to a single centralized TCU that performs PTWs to memory. Each TBU can be located in its own clock and power domain making it easy to co-locate the TBU with the peripheral requiring translation. Each TBU communicates to the TCU over an point-to-point stream interface and with bus masters over ACE-Lite. The TCU has an AXI4 slave interface for configuration.
Get support
Community Forums
Suggested answer Which ARM board will be most suitable?
  • Video Processor Embedded Algorithms
  • Video Processor
0 votes 1648 views 3 replies Latest 17 hours ago by Dharmalingam.K Answer this
Suggested answer In AXI Why there is a read response in each data transfer? 0 votes 5377 views 4 replies Latest yesterday by Jenniferl Answer this
Not answered Making ONVIF conformant surveillance camera with STM32H743.
  • stm32 h7
0 votes 62 views 0 replies Started yesterday by Akash Kasturi Answer this
Answered IP Camera interface via STM32
  • Cortex-M
  • STM32F
  • Cortex-M4
1 votes 36218 views 8 replies Latest yesterday by Akash Kasturi Answer this
Not answered LPC2138 Program Execution Issue 0 votes 98 views 0 replies Started yesterday by kishor potdar Answer this
Suggested answer Hard fault handler problem - Cortex-M0+
  • R13 (SP Stack Pointer)
  • 3 (HardFault)
0 votes 439 views 1 replies Latest 6 days ago by Clonimus74 Answer this
Suggested answer Which ARM board will be most suitable? Latest 17 hours ago by Dharmalingam.K 3 replies 1648 views
Suggested answer In AXI Why there is a read response in each data transfer? Latest yesterday by Jenniferl 4 replies 5377 views
Not answered Making ONVIF conformant surveillance camera with STM32H743. Started yesterday by Akash Kasturi 0 replies 62 views
Answered IP Camera interface via STM32 Latest yesterday by Akash Kasturi 8 replies 36218 views
Not answered LPC2138 Program Execution Issue Started yesterday by kishor potdar 0 replies 98 views
Suggested answer Hard fault handler problem - Cortex-M0+ Latest 6 days ago by Clonimus74 1 replies 439 views
