Static Memory Controllers
The Arm CoreLink Static Memory Controllers
Static Memory Controller Block Diagram.
Getting Started
Static or Non-volatile memory is typically a shared resource to which many different masters and processes require access. Effective, error-free access to static memory is important for both system performance and system power.
The CoreLink Static Memory Controllers (SMC) provide efficient interfaces to a wide range of types of non-volatile memory, applying the features of AMBA AXI to schedule requests to the memory in the most optimal way. They are designed for compatibility with the Arm portfolio of Memory ControllersCoreLink Interconnect and Processor solutions emphasizing low-power and high-performance operation.
Why choose a CoreLink Static Memory Controller?
Most systems with Arm processors have off-chip static (non-volatile) memories. These contain information such as object code and data files. System performance depends on being able to read and write this data efficiently and accurately. CoreLink Static Memory Controllers are available for AMBA AXI (SMC-35X) and AMBA AHB (PL24X). These controllers are optimized for the bus protocol and have been developed to complement the CoreLink Network Interconnect, and Dynamic Memory Controllers along with Arm CPU and media processors.
Verification and Benchmarking
Understanding the performance and functionality of the memory controller in a system context is critical to the specification and development of the controller. The system level verification and benchmarking ensure the delivery of products that have been fully qualified alongside the cores and on-chip interconnect. These results then drive the specifications of both current and future memory controllers. They ensure efficient, low-risk, easy to integrate solutions that enable development to proceed smoothly - meeting performance goals and delivering time to market.
And for the future?
Arm is committed to ensuring the Arm ecosystem has the memory controller solutions in demand. Arm participates in the industry standards bodies defining new memory interfaces. Collaboration with Arm teams developing new cores and new interconnects ensures that memory interface support for new products is available when needed.
How to choose
AXI Static Memory Controllers
The SMC-35X family of products provides an interface between AXI interconnects and a range of non-volatile memories. The SMC-35X has a wide range of configurable parameters, these are described under the specifications tab.
Product
Non-Volatile Memory Supported
Notes
SMC-351
NAND Flash
up to 4 chip selects
SMC-352
NOR Flash / SRAM
SMC-353
NAND Flash and NOR Flash / SRAM
up to 4 NAND and 4 NOR/SRAM
SMC-354
NOR Flash / SRAM
up to 8 chip selects in 2 groups of 4
AHB Memory Controllers
The PL24X family products provide an interface between AHB interconnects and non-volatile memory. These are hybrid controllers also providing an interface to DRAM memory systems.
Other combinations of memory can be supported by using a combination of the CoreLink Network Interconnect product with DMC-34X and SMC-35X memory controllers.
 Product NV Memory Supported  DRAM Support  AHB Ports
 PL241 NOR/SRAM  None  1
 PL242 NAND  SDR  4
 PL243 NOR/SRAM  SDR  4
 PL244 NAND  DDR  6
 PL245 NOR/SRAM  DDR  6
Get support
Community Blogs
Community Forums
Suggested answer I2C problem on Cypress PSoC3 (with EEPROM and FRAM too) 0 votes 5213 views 5 replies Latest yesterday by Andy Neil Answer this
Suggested answer application which takes audio input from uart and give text output 1 votes 3864 views 1 replies Latest 2 days ago by verduy Answer this
Suggested answer JTAG/SWD and entering debug monitor
  • Debug Adapters
0 votes 4227 views 2 replies Latest 3 days ago by vaiyawa Answer this
Suggested answer how to covert Speech to text 1 votes 5827 views 2 replies Latest 3 days ago by vaiyawa Answer this
Not answered AHB Lite 0 votes 314 views 0 replies Started 5 days ago by Jenish Radadiya Answer this
Suggested answer Design considerations for implementing flash program download
  • CoreSight Architecture
  • SWD
  • Debug Access Port (DAP)
0 votes 5931 views 3 replies Latest 5 days ago by Mohamed Nasser Answer this
Suggested answer I2C problem on Cypress PSoC3 (with EEPROM and FRAM too) Latest yesterday by Andy Neil 5 replies 5213 views
Suggested answer application which takes audio input from uart and give text output Latest 2 days ago by verduy 1 replies 3864 views
Suggested answer JTAG/SWD and entering debug monitor Latest 3 days ago by vaiyawa 2 replies 4227 views
Suggested answer how to covert Speech to text Latest 3 days ago by vaiyawa 2 replies 5827 views
Not answered AHB Lite Started 5 days ago by Jenish Radadiya 0 replies 314 views
Suggested answer Design considerations for implementing flash program download Latest 5 days ago by Mohamed Nasser 3 replies 5931 views
