AMBA cache controllers are a collection of controller IP that Arm offers to enhance the system performance of microcontrollers. These controllers are low-power and optimized to perform critical tasks within the AMBA system. Designed for compatibility with Arm Cortex, Mali multimedia, and CoreLink system IP, they are the natural complement to interconnect and memory controllers.
Go to section:
CoreLink L2C-310 level 2 cache controller | CoreLink AHB Cache | CoreLink AHB Flash Cache | SSE-200 instruction Cache
Processor to off-chip memory communication has become the performance bottleneck in many SoCs. Level 2 cache controllers improve processor performance by keeping memory access on-chip with a typical latency between 10-25% for accessing the data off-chip. At the same time, the reduced processor demands on the off-chip memory bandwidth free up that resource for other masters.
Level 2 cache controllers also contribute significantly to power efficiency because on-chip accesses are typically lower in power when compared to going off-chip. CoreLink level 2 cache controllers can be embedded in the processor, or delivered as standalone components. The level 2 cache controllers are designed alongside the processor to match the processor requirements and easily integrate into AMBA AXI or AHB interconnects.
The CoreLink L2C-310 cache controller is a high-performance, AXI level 2 cache controller that is designed and optimized to address Arm processors that have an AXI system interface. The processors include:
View the L2C-310 Technical Reference Manual:
View
CoreLink AHB Cache
Memory sizes required for applications are increasing for both on and off-chip memories across various technologies such as SRAM, PSRAM, Flash and DRAM. Typically, a larger size has a direct implication on the memory access latency. Slower memories and higher latency memories could have a significant impact on the system performance of AHB-based processors. As the capabilities of microcontrollers are set to increase over time, a solution is required to store frequently used data, and ensure system performance does not reduce.
The Arm CoreLink AHB Cache has been designed to reduce the impact of high system memory latency. It is a versatile cache for data and code. Depending on the application, when the AHB Cache has many cache hits, it lowers an SoCs power and overall memory access latency due to reduced system memory access.
CoreLink AHB Cache
Other key features include:
  • 4-way set associative
  • Zero bus wait state when the access is a cache hit.
  • Cache size of 2kB to 64kB
  • Cache line size of 32B
  • Configurable Write-Through or write-back policy
  • Pseudo-random replacement policy
  • Support for hit and miss counters.
  • Supports Q-Channel based power control.
  • Supports software cache maintenance operations
CoreLink AHB Cache can be added to a system in several configurations for different IoT and embedded use cases. It supports 32-bit AMBA 5 AHB with TrustZone for Armv8-M support. It is compatible with the following processor IP:
View the CoreLink AHB Cache Technical Reference Manual:
View
The CoreLink AHB Flash Cache is an instruction cache that is instantiated between the bus interconnect and the eFlash controller. It is designed to improve power efficiency in Cortex-M-based designs, and improve code fetching performance in a system.
The cache is for on-chip embedded Flash (eFlash) and is optimized for fetching Cortex-M processor instructions directly from an eFlash. Other key features include:
  • 128-bit data interface for the master and 32-bit data interface for the slave
  • 2-way associative or direct mapped
  • Four words per line (16B cache line size)
  • Optional support for configurable hit and miss counters.
CoreLink AHB Flash Cache is a part of the Arm Corstone-102, Corstone-201, Corstone-300, and Corstone-700.
View the AHB Flash Cache Technical Reference Manual:
View
SSE-200 Instruction Cache
The Instruction Cache integrated in the SSE-200 subsystem is designed to reduce the code access fetches that are targeting the flash memory, to improve the flash and power of the subsystem. The Instruction Cache also reduces the overall latency of code access.
The SSE-200 Instruction Cache is optimized for systems based on the Cortex-M33 processor, supporting TrustZone for Armv8-M. It is a part of Arm Corstone-201. Other key features include:
  • 2-way set associative
  • 16-Byte cache lines
  • Configurable size
  • Configuration interface local to each processor
  • Supports uncached bypass operation
View the Instruction Cache technical reference manual
View
Start designing now
Arm Flexible Access gives you quick and easy access to this IP, relevant tools and models, and valuable support. You can evaluate and design solutions before committing to production, and only pay when you are ready to manufacture.
Learn more
Get support
Community Forums
Suggested answer Making ONVIF conformant surveillance camera with STM32H743.
  • stm32 h7
0 votes 67 views 1 replies Latest 5 hours ago by ibrahim1236 Answer this
Suggested answer Which ARM board will be most suitable?
  • Video Processor Embedded Algorithms
  • Video Processor
0 votes 1649 views 3 replies Latest 18 hours ago by Dharmalingam.K Answer this
Answered UART + DMA: how to ? 0 votes 1686 views 6 replies Latest 22 hours ago by Colin Campbell Answer this
Suggested answer m1/m3 design start download problems 0 votes 82 views 2 replies Latest 23 hours ago by ChrisR Answer this
Suggested answer In AXI Why there is a read response in each data transfer? 0 votes 5378 views 4 replies Latest yesterday by Jenniferl Answer this
Not answered IMPRECISERR on Cortex-M33 r0p3
  • Cortex-M33
0 votes 61 views 0 replies Started yesterday by Zbynek Mynar Answer this
Suggested answer Making ONVIF conformant surveillance camera with STM32H743. Latest 5 hours ago by ibrahim1236 1 replies 67 views
Suggested answer Which ARM board will be most suitable? Latest 18 hours ago by Dharmalingam.K 3 replies 1649 views
Answered UART + DMA: how to ? Latest 22 hours ago by Colin Campbell 6 replies 1686 views
Suggested answer m1/m3 design start download problems Latest 23 hours ago by ChrisR 2 replies 82 views
Suggested answer In AXI Why there is a read response in each data transfer? Latest yesterday by Jenniferl 4 replies 5378 views
Not answered IMPRECISERR on Cortex-M33 r0p3 Started yesterday by Zbynek Mynar 0 replies 61 views
