CoreLink DMC-620
The Arm CoreLink DMC-620 Dynamic Memory Controller
Getting Started
The Arm CoreLink DMC-620 Dynamic Memory Controller is designed to provide an optimal memory access solution for SoCs deployed in infrastructure applications such as servers, High-Performance Computing (HPC), and networking.
  • Delivers best performance with ECC and RAS for data transfers from SoC to high-density DRAM memory.
  • Best combination of features, power, cost, and performance.
  • Fast, single-port CHI.B interface for transferring data from CMN-600 to DDR4/3 DRAM memories.
CMN-600 System Diagram.
Specifications
Features Details
System interface x for direct connection to CCN-5xx or CMN-600 products using AMBA 5 CHI
System data width 256-bit or 128-bit
Configuration APB
Memory interfaces Single interface per channel, which is connected to PHY with DFI 4.0
Memory type DDRS, DDR3(L), and DDR4 with support for UDIMM, RDIMM, LRDIMM, and NVDIMM-N
Maximum DDR speeds Up to DDR4-3200 Mbps
Memory width x72 or x40 bit (including 8-bit ECC)
ECC SECDED or symbol-based ECC
Chip Selects (per channel) 8
QoS QoS based scheduling algorithm, non-blocking paths to DRAM through CMN
Latency QoS mechanisms that ensure critical masters can achieve minimum latency
Low power All DRAM power modes are supported and hierarchical clock gating throughout the DMC
CoreLink DMC-620 key features
Lowest memory latency with highest bandwidth utilization delivering QoS with RAS
The Arm CoreLink DMC-620 delivers best performance for data transfers from SoC to high-density DRAM memory
  • Delivers up to 95% of maximum memory bandwidth utilization
  • Reduces static pipeline latency by up to 50% from previous generation CoreLink DMC-520
  • Provides optimized performance and end-to-end QoS with CoreLink CMN-600
Reliability, Availability, and Serviceability (RAS) is a key requirement for SoCs deployed in infrastructure applications. The CoreLink DMC-620 offers support for sophisticated RAS features such as end-to-end data parity protection, corrected data write-back, retry on uncorrectable ECC errors, memory scrubbing, and standardized error reporting. It supports both the standard SECDED (Single Error Correct Multiple Error Detect) and advanced symbol-based ECC for correcting complete failure of a x4 memory device.
DMC-620 Feature Diagram.
In-built memory access security for your SoC
CoreLink DMC-620 provides integrated Arm TrustZone Address Space Control (TZASC) enabling programmable memory access protection for different masters in the SoC. Integration of TZASC functionality within the memory controller saves gate area and latency cycles as memory access rights are evaluated in parallel with other memory controller functions.
Dual-in-line-memory module (DIMM) and high-density DRAM support
CoreLink DMC-620 supports multiple DIMM standards - UDIMM, RDIMM, and LRDIMM. Moreover, it has extended virtual rank support to enable addressing of very high-density 2H, 4H, or 8H 3DS DRAM devices. With this support, a single channel of CoreLink DMC-620 can address up to 1TB of DRAM memory, providing system designers with sufficient headroom for growing the DRAM footprint of their high-end systems.
Fast, single-port AMBA 5 CHI interface
CoreLink DMC-620 integrates with CoreLink CMN-600 supporting the latest Arm 64-bit processors and high frequency AMBA 5 CHI (Coherent Hub Interface). The fast, non-blocking CHI port on CoreLink DMC-620 ensures access to memory for multiple, competing masters guaranteeing that there are no unexpected blocks to flow of data to and from memory.
Reduce development cost and improve time-to-market
CoreLink DMC-620 has the best combination of features, power, cost, and performance. It is built on top of a family of silicon-proven DMC products that guarantee interoperability with any DFI-compliant DDR PHY and with JEDEC-compliant DDR4, DDR3, and DDR3L DRAM memory. Deploying CoreLink DMC-620 in your SoC delivers considering cost savings and helps to accelerate your tape-out. These cost savings come from not only the development itself but also from multiple person-years that Arm spends in optimizing, tuning, and validating performance and interoperability in a real sub-system.
  • TRM
  • CoreLink DMC-620 Technical Reference Manual
    For system designers, system integrators and programmers who are designing a SoC, the Technical Reference Manual is the go-to resource.
    DMC-620 TRM
  • A guide on software optimization.
  • AMBA 5 CHI Specification
    CoreLink DMC-620 is built on AMBA CHI specification, which is Arm's advanced coherent interconnect for high data transfer bandwidths at GHz and above frequencies.
    AMBA specs
Get support
Community Forums
Suggested answer After first execution control goes to task 2 but i want him to go to task1 what i suppose to do here?
  • Real Time Operating Systems (RTOS)
0 votes 216 views 1 replies Latest yesterday by fixxxer Answer this
Suggested answer Is there any extra parameter needed to start networking on FVP_MPS2_M7 simulator?
  • Embedded Software
  • Cortex-M7
  • Simulation
  • Cortex-M3
  • networking
  • Fast Models
  • Cortex-M7 FVP
0 votes 928 views 1 replies Latest yesterday by fixxxer Answer this
Suggested answer L1 cache BW 0 votes 460 views 2 replies Latest yesterday by fixxxer Answer this
Suggested answer Making ONVIF conformant surveillance camera with STM32H743.
  • stm32 h7
0 votes 830 views 5 replies Latest 3 days ago by ibrahim1236 Answer this
Suggested answer Which ARM board will be most suitable?
  • Video Processor Embedded Algorithms
  • Video Processor
0 votes 1693 views 3 replies Latest 4 days ago by Dharmalingam.K Answer this
Suggested answer In AXI Why there is a read response in each data transfer? 0 votes 5433 views 4 replies Latest 4 days ago by Jenniferl Answer this
Suggested answer After first execution control goes to task 2 but i want him to go to task1 what i suppose to do here? Latest yesterday by fixxxer 1 replies 216 views
Suggested answer Is there any extra parameter needed to start networking on FVP_MPS2_M7 simulator? Latest yesterday by fixxxer 1 replies 928 views
Suggested answer L1 cache BW Latest yesterday by fixxxer 2 replies 460 views
Suggested answer Making ONVIF conformant surveillance camera with STM32H743. Latest 3 days ago by ibrahim1236 5 replies 830 views
Suggested answer Which ARM board will be most suitable? Latest 4 days ago by Dharmalingam.K 3 replies 1693 views
Suggested answer In AXI Why there is a read response in each data transfer? Latest 4 days ago by Jenniferl 4 replies 5433 views
