CoreLink DMC-520
The Arm CoreLink DMC-520 Dynamic Memory Controller
Getting Started
The CoreLink DMC-520 Dynamic Memory Controller provides highest bandwidth with low latency access to DDR4 and DDR3 memory in server, networking, and high-performance computing applications. The DMC-520 provides for full DIMM support along with RAS (Reliability, Availability, and Serviceability) and advanced error correction features that are necessary for these infrastructure applications.
  • Delivers best performance with ECC and RAS for data transfers from SoC to high-density memory.
  • Best combination of features, power, cost, and performance.
  • Fast, single-port CHI.A interface for transferring data to DDR4 and DDR3 DRAM memories.
Diagram on enterprise for CCN502 to 512.
Specifications
Features Details
AMBA interface CHI
System interface
System data width 128 bit
Configuration APB interface
Memory interfaces Single DFI 3.1 memory interface with configurable 1:1, 1:2, or 1:4 DFI frequency ratio
Memory types DDR3, DDR3(L),and DDR4
Memory width x40/x72 bit DRAM (includes 8 bits of ECC)
ECC SECDED or enhanced symbol-based ECC
QoS QoS based scheduling algorithm, non-blocking paths to DRAM through CCN
Low power All DRAM power modes are supported and hierarchical clock gating throughout the DMC
DMC-520 Block Diagram.
CoreLink DMC-520 key features
System Optimized DMC with support for single 128-bit wide AMBA 5 CHI system interface
  • Integrated TrustZone address space control functionality in system interface to provide secure memory access.
Support for advanced ECC, RAS,and DIMM capabilities
  • Includes both standard SECDED ECC and advanced symbol-based ECC for correcting failure of X4 chip.
  • DDR3, DDR3L, and DDR4 memories (up to DDR4-3200 speeds) with UDIMM, RDIMM, LRDIMM, and 3DS support.
Quality-of-Service (QoS)
  • QoS improvements over previous generation reducing average and maximum CPU latency.
  • End-to-end QoS optimized with CCN interconnect and Arm v8.x CPUs.
Industry-standard DFI 3.1 Interface
  • Proven interoperability with third-party DFI 3.1 compatible DDR PHYs.
CoreLink DMC-520 Characteristics
CoreLink DMC-520 supports DDR4 which is the most advanced infrastructure-class memory technology available today. DDR4 provides the highest bandwidth (up to 25GB/s per channel for DDR4-3200 Mbps) which supporting reliability and low power features necessary for high-end systems deployment. System-wide QoS for DMC-520 designed and tested with CoreLink CCN Family, Cortex A53, and Cortex A72 processors.
  • TRM
  • CoreLink DMC-520 Technical Reference Manual
    For system designers, system integrators and programmers who are designing a SoC, the Technical Reference Manual is the go-to resource.
    DMC-520 TRM
  • A guide on software optimization.
  • AMBA 5 CHI Specification
    CoreLink DMC-520 is built on AMBA CHI specification, which is Arm's advanced coherent interconnect for high data transfer bandwidths at GHz and above frequencies.
    AMBA specs
Get support
Community Blogs
Community Forums
Suggested answer AHB-lite Slave Burst Operation
  • AHB-Lite
0 votes 257 views 2 replies Latest 11 hours ago by eugch Answer this
Answered how to calculate unaligned address for APB? 0 votes 11062 views 8 replies Latest 4 days ago by Colin Campbell Answer this
Suggested answer APB4 PSTRB 0 votes 315 views 1 replies Latest 6 days ago by Colin Campbell Answer this
Suggested answer AHB Lite 0 votes 1346 views 1 replies Latest 7 days ago by Colin Campbell Answer this
Suggested answer Porting to U-boot driver model and device tree control (for ARM-based design)
  • Peripheral Devices
  • U-Boot
0 votes 2582 views 1 replies Latest 13 days ago by rwl Answer this
Not answered Ulink pro debugging in custom SoC
  • Custom SoC
  • ulinkpro
  • SoC Verification
0 votes 348 views 0 replies Started 18 days ago by ronit Answer this
Suggested answer AHB-lite Slave Burst Operation Latest 11 hours ago by eugch 2 replies 257 views
Answered how to calculate unaligned address for APB? Latest 4 days ago by Colin Campbell 8 replies 11062 views
Suggested answer APB4 PSTRB Latest 6 days ago by Colin Campbell 1 replies 315 views
Suggested answer AHB Lite Latest 7 days ago by Colin Campbell 1 replies 1346 views
Suggested answer Porting to U-boot driver model and device tree control (for ARM-based design) Latest 13 days ago by rwl 1 replies 2582 views
Not answered Ulink pro debugging in custom SoC Started 18 days ago by ronit 0 replies 348 views
