Getting Started
The Arm CoreLink Network Interconnect (NIC) family offers highly configurable topology with Network on Chip (NoC)-like properties that enable you to build high performance, optimized, AMBA-compliant SoC connectivity. The CoreLink NIC family is configurable across a wide range of applications from a single bridge component, for example an AHB to AXI protocol bridge, to a complex infrastructure that consists of up to 128 masters and 64 slaves in a combination of different AMBA protocols.
  • CoreLink NIC-450 Network Interconnect Chip.
  • CoreLink NIC-450
    • Library of key interconnect IP that enables designers to build a scalable and configurable NIC.
    • Available with a tooling automation flow using CoreLink Creator that employs algorithms to accelerate configuration based on design requirements.
    • Enables integrated tooling Socrates DE (licensed separately) for configuring complex interconnect subsystem designs.
    • Includes all NIC-400 features.
  • CoreLink NIC-400 Network Interconnect Chip.
  • CoreLink NIC-400
    • Fully configurable, hierarchical, low latency, low power connectivity for AMBA 4 AXI4, AXI3, AHB-Lite and APB interfaces.
    • Scalable for multiple applications from simple single core designs, up to large coherent systems as a companion to CoreLink CCI and CCN coherent interconnects.
    NIC-400 TRM
NIC-450 and CoreLink Creator
CoreLink Creator with its harvesting flows and enhanced tooling environment provides significant improvements to configure NICs, which decreases time to market.
Functional enhancement in NIC-400r1 with QVN-terminate feature to resolve head-of-line blocking when accessing DRAM provide:
  • Improved support for QVN with DMC controllers using sideband QOSACCEPT signaling, supported in DMC-500 and other 3rd party DMC providers.
  • CPU latency reduction with QoS enhancements, designed and tested with Arm memory controllers such as CoreLink DMC-500.
Start designing now
Arm Flexible Access gives you quick and easy access to this IP, relevant tools and models, and valuable support. You can evaluate and design solutions before committing to production, and only pay when you’re ready to manufacture.
CoreLink ADB-400
The CoreLink ADB-400 AMBA Domain Bridge is an asynchronous bridge between two components or systems that can be in a different power, clock, or voltage domains.
The ADB-400 supports:
  • An optional configurable destination register for the payload of each channel.
  • Simple reset requirements.
  • A power management interface.
  • Dynamic Voltage and Frequency Scaling (DVFS).
  • Quality of Service (QoS) Virtual Network (QVN).
  • Clock status indication.
The ADB-400 consists of a slave domain and a master domain. The slave domain received transfers from the AMBA master and the master domain transmits transfers to an AMBA slave.
CoreLink XHB-400
The XHB converts AXI4 protocol to AHB-Lite protocol and has an AXI4 slave interface and an AHB-Lite master interface.
AXI4 slave interface: This connects to either the AXI4 master interface of a processor or to an AXI interconnect.
AHB-Lite master interface: This implements an AHB-Lite master to drive AHB-Lite subsystems.
XHB-400 TRM
NIC-450 Library of Interconnect IP
Network Interconnect NIC-400
Advanced Quality of Service QoS-400
 Virtual Networks QVN-400
 Thin Links TLX-400
 AMBA Domain Bridge ADB-400
 AXI-to-AHB Bridge XHB-400
 Low-power distributor LPD-500
Get support
Community Forums
Suggested answer Making ONVIF conformant surveillance camera with STM32H743.
  • stm32 h7
0 votes 71 views 1 replies Latest 5 hours ago by ibrahim1236 Answer this
Suggested answer Which ARM board will be most suitable?
  • Video Processor Embedded Algorithms
  • Video Processor
0 votes 1649 views 3 replies Latest 18 hours ago by Dharmalingam.K Answer this
Suggested answer In AXI Why there is a read response in each data transfer? 0 votes 5378 views 4 replies Latest yesterday by Jenniferl Answer this
Answered IP Camera interface via STM32
  • Cortex-M
  • STM32F
  • Cortex-M4
1 votes 36221 views 8 replies Latest yesterday by Akash Kasturi Answer this
Not answered LPC2138 Program Execution Issue 0 votes 98 views 0 replies Started yesterday by kishor potdar Answer this
Suggested answer Hard fault handler problem - Cortex-M0+
  • R13 (SP Stack Pointer)
  • 3 (HardFault)
0 votes 439 views 1 replies Latest 6 days ago by Clonimus74 Answer this
Suggested answer Making ONVIF conformant surveillance camera with STM32H743. Latest 5 hours ago by ibrahim1236 1 replies 71 views
Suggested answer Which ARM board will be most suitable? Latest 18 hours ago by Dharmalingam.K 3 replies 1649 views
Suggested answer In AXI Why there is a read response in each data transfer? Latest yesterday by Jenniferl 4 replies 5378 views
Answered IP Camera interface via STM32 Latest yesterday by Akash Kasturi 8 replies 36221 views
Not answered LPC2138 Program Execution Issue Started yesterday by kishor potdar 0 replies 98 views
Suggested answer Hard fault handler problem - Cortex-M0+ Latest 6 days ago by Clonimus74 1 replies 439 views
