Getting Started
Hardware-managed cache coherency is a fundamental technology to scale system performance and enable heterogeneous processing. Hardware cache coherency is a requirement to enable big.LITTLE processing that allows the operating system to choose the right processor for the right job. The Arm CoreLink CCI family of products has been designed into many applications including mobile, tablet, digital TV, set top box, automotive, and low-cost infrastructure. In addition to full coherency for processor clusters with AMBA 4 ACE, the CCI family is also used to provide high performance I/O coherency for accelerators and interfaces using AMBA 4 ACE-Lite.
CoreLink CCI-550
  • Full coherency with up to six clusters including big.LITTLE and coherent accelerators
  • Fully coherent GPU support to enable heterogeneous processing with shared virtual memory
  • Higher performance and power efficiency with integrated snoop filter
CoreLink CCI-500
  • Full coherency with up to four clusters including big.LITTLE and coherent accelerators
CoreLink CCI-400
  • Full coherency with up to two clusters, essential for big.LITTLE
  • Smallest cache coherent interconnect
Product Comparison
CoreLink CCI-550
CoreLink CCI-500
CoreLink CCI-400
Summary Highly configurable ACE interconnect supporting up to 6 clusters Highly configurable ACE interconnect supporting up to 4 clusters Smallest area, 2 cluster coherent interconnect
Fully coherentACE Slave Interfaces
1-6 1-4 2
Processors
 Up to 24 cores Up to 16 cores
Up to 8 cores
IO CoherentACE-Lite Slave Interfaces
0-6
(maximum 7 ACE and ACE-Lite slave ports)
0-6
1-3
System and DMC Master Interfaces
1-6 memory interfaces
1-3 system
1-4 memory interfaces
1-2 system
1-2 memory interfaces
1 system
Memory map
32-48 bit Physical address
40/44/48 bit DVM
32-44 bit Physical address
40/44/48bit DVM
40 bit Physical address
44 bit DVM
Coherency and Snoop Filter
Integrated snoop filter maintains directory of processor cache contents and reduces CPU snoops Integrated snoop filter maintains directory of processor cache contents and reduces CPU snoops
Broadcast snoop coherency
QoS Integrated QoS mechanisms
Power, Area, Frequency Contact Arm for more information
Hardware Cache Coherency Introduction
Coherency is about ensuring all processors, or bus masters in the system see the same view of memory. For example, if you have a processor which is creating a data structure then passing it to a DMA engine to move, both the processor and DMA must see the same data. If that data were cached in the CPU and the DMA reads from external DDR, the DMA will read old, stale data.
There are three mechanisms to maintain coherency:
  • Disable caching is the simplest mechanism but can cost significant CPU performance. To get the highest performance, processors are pipelined to run at high frequency, and to run from caches that offer a very low latency. Caching data that is accessed multiple times increases performance significantly and reduces DRAM accesses and power. Marking data as “non-cached” could impact performance and power.
  • Software managed coherency is the traditional solution to the data sharing problem. The software, usually device drivers, must clean or flush dirty data from caches, and invalidate old data to enable sharing with other processors or masters in the system. This takes processor cycles, bus bandwidth, and power.
  • Hardware managed coherency offers an alternative to simplify software. With this solution, any cached data marked "shared" is always automatically up to date. All processors and bus masters in that sharing domain see the exact same value.
Extending hardware coherency to the system requires a coherent bus protocol, and in 2011 Arm released the AMBA 4 ACE specification which introduced the AXI Coherency Extensions on top of the popular AXI protocol. The full ACE interface allows hardware coherency between processor clusters and allows an SMP operating system to extend to more cores. With the example of two clusters, any shared access to memory can snoop into the other cluster’s caches to see if the data is already on chip. If not, it is fetched from external memory (DDR). The AMBA 4 ACE-Lite interface is designed for IO (or one-way) coherent system masters like DMA engines, network interfaces and GPUs. These devices might not have any caches of their own, but they can read shared data from the ACE processors. Alternatively, they might have caches but not cache shareable data. While hardware coherency can add some complexity to the interconnect and processors, it massively simplifies the software and enables applications that would not be possible with software coherency. An example being big.LITTLE Global Task Scheduling.
Get support
Community Forums
Answered osMutexWait() function before the RTX osKernelInitialize() 0 votes 292 views 9 replies Latest yesterday by Andy Neil Answer this
Answered Code jumps to cxsync1 in vectors.S?
  • Arm Development Studio
0 votes 424 views 2 replies Latest yesterday by DanijelDomazet Answer this
Answered Keil uVision compiling with API Issues
  • STM32F4DISCOVERY
  • Windows 10
  • api
  • uVision
  • Compilation error
0 votes 217 views 3 replies Latest yesterday by KevinM Answer this
Answered TTBR1_EL2 mmu translation information wrong when E2H=1 0 votes 1153 views 4 replies Latest 2 days ago by lemin9538 Answer this
Answered Breakpoints not working in C code, only in assembly?
0 votes 904 views 7 replies Latest 2 days ago by Danijel Answer this
Answered Fault Injection in ROM. 0 votes 464 views 6 replies Latest 3 days ago by Broeker Answer this
Answered osMutexWait() function before the RTX osKernelInitialize() Latest yesterday by Andy Neil 9 replies 292 views
Answered Code jumps to cxsync1 in vectors.S? Latest yesterday by DanijelDomazet 2 replies 424 views
Answered Keil uVision compiling with API Issues Latest yesterday by KevinM 3 replies 217 views
Answered TTBR1_EL2 mmu translation information wrong when E2H=1 Latest 2 days ago by lemin9538 4 replies 1153 views
Answered Breakpoints not working in C code, only in assembly? Latest 2 days ago by Danijel 7 replies 904 views
Answered Fault Injection in ROM. Latest 3 days ago by Broeker 6 replies 464 views
